I have been having issues with video freezing when a video is loaded into the 2nd deck while one is playing on the 1st. After many hours of experimentation this is what I have come up with:
If you load a video and VDJ analyzezs it, the second time it loads it loads much quicker, doesn't use nearly as much CPU and does not cause freezing.
Okay - so I enable write to VDJ tag and analyze all of my videos. They work okay until you shut the computer off then same problem when you restart the program. VDJ doesn't remembr having analyzed them. I have set up a keyboard shortcut to save my Database before I exit but this does not help.
What am I doing wrong? This is getting very frustrating!
geposted Fri 04 May 07 @ 9:28 pm
