Hello!!
I`ve got a probelm with the Echo Plugin (Home Edition)
If I use the mute (echo) effect on the left Deck it works normal. The music gets lower and lower.
But if I do the same on the right deck, the musik just stops!!
Has nothing to do with default Deck or if the left or right deck is selceted!
Its everytime the same, sometimes the hole program crashes if I use the "Mute" in the echo effect.
As a consequence its always dangerous to use this effect while recording ...
Please help me!
Thank you
Hopper DJ
Please help me!
Thank you
Hopper DJ
geposted Wed 09 May 07 @ 2:16 pm
Hmm Thank you for the help!!! :(
geposted Sun 03 Jun 07 @ 4:19 pm
Hi HopperDJ,
Sorry nobody got back to you. I've been on the forums for quite a while now and I havn't heard of this problem before.
Maybe your best bet is to contact support. (Click on Help, then Ask a question).
Good luck.
Oh, before you contact support, you could try uninstalling and reinstalling the software just to see if it makes any difference. Might be the first thing they ask you to try anyway.
Good luck.
geposted Sun 03 Jun 07 @ 10:27 pm
please make a support ticket
contact
contact
geposted Sun 03 Jun 07 @ 11:21 pm
Hey!!
Now I got at least an answer :)
I think the problem is with the effect itself.
Bacause I found out that if I wait, lets say, about 1 minute then the programm works normal. But within this time it does not react to any order and does not show, e.g. the turntalbes movin. But the music is still playing ... The other times before I just shut VDJ down because I thought it collapsed.
I will make a support ticket within the next time.
Thank you for your answers!
Greets HopperDJ
Greets HopperDJ
geposted Wed 06 Jun 07 @ 8:13 pm
Same here with Echo its will do the same exact thing everytime
geposted Wed 07 Jan 09 @ 6:18 pm
