Could someone map it please. I have it but i miss virtual dj. I have tried to map thanks to learn command. I manage to map all execept the jog wheel. It cannot navigate in the sound by rotate
geposted Sun 03 Jun 07 @ 6:31 pm
you will need vdj pro for this purpose after the demo expires
as the console edition has no midi mapping capabilities
hope to see you with us soon :)
geposted Sun 03 Jun 07 @ 6:37 pm
I have the pro version (that's how I manage to map the buttons and faders). The problem is that I can map the jog wheel well. I don't manage to have something good.
Could you help me?
Could you help me?
geposted Sun 03 Jun 07 @ 10:05 pm
perhaps you could add your serial if you own the pro version
geposted Sun 03 Jun 07 @ 10:52 pm
Can I have an answer please?Can Virtual dj pro allow to use xponent with full fonctions (included jog wheel navigation...scratch....)
geposted Mon 04 Jun 07 @ 11:41 am
yes it can , to map an action
just press and hold a button , and tell it what to do
or turn a dial
or move a jog ect
midi mapping
hope to see you soon as a pro user
or turn a dial
or move a jog ect
midi mapping
geposted Mon 04 Jun 07 @ 12:21 pm
I thank you for the answer But i think you didn't read the first post (and the others). Mapping the buttons is always such easy. What I was talking about is mapping the jog wheel to be able to navigate and scratch
geposted Thu 07 Jun 07 @ 12:24 pm
Its the same prob as the jogs on the vci and xone 3d, they are working on it.
geposted Thu 07 Jun 07 @ 12:34 pm
ok thanks
geposted Thu 07 Jun 07 @ 11:35 pm
Do you get the Xponent soundcard to work with Virtual DJ, and the leds ?
geposted Thu 28 Jun 07 @ 8:17 pm
i think to get the leds to work some sort of native mapping would need to be created by virtual dj
geposted Thu 28 Jun 07 @ 8:55 pm
Its a really good controller, really good grade.
http://www.virtualdj.com/forums/72382/Hardware_Technical_Support/M-audio_Xponent_Controller.html
geposted Fri 29 Jun 07 @ 7:42 am
HI mastahk.
Can you please tell me the dimentions of it. (?)W,(?)D,(?)H.
look on google, online stores. nothing.........
I even download the user manual from m-audio. but nothing.
I buy 6 monht ago the BCD2000 and have to stay back with the MP3 console. I was wating for second edition from vestax (with sound card). but theyr seems very quiet about it.
Wating for the team to support the TORK. then buy it.
The support for the BCD2000 was no full.
THANKS
THANKS
geposted Fri 13 Jul 07 @ 4:47 pm
i did some mapping on virtual dj with my xponent. i was able to get the touch sensitive feel on it and also i was able to get it to scratch, but the only problem, the scratches did not come out good as scratching with a mouse. so right now my mappings is "work in progress". once i get the scratches to sound good, then i would say my job is complete. i tried scratching on traktor dj with xponent and it sounded like the real thing. i did some unbelievable scratches on traktor dj with it. is there anyone who have tried to tweak the scratching on virtual dj with xponent........
geposted Mon 03 Sep 07 @ 4:08 am
Hi, I have mapped everything else on VDJ except for the jog wheels, please advise how or what values you have used to map the jogs...I can live without any LEDS, but need the jog wheel...
geposted Mon 03 Sep 07 @ 11:48 am
I just got VDJ Pro last night and was really excited to try it out with my M-AUDIO XPONENT. After reading a couple of reviews on different threads of the unit and its compatibility with VDJ I was eager to get this software. I must be doing something wrong because the unit is not working the way they described. Are there tweaks that I need to make to get the Scratchwheel function to work properly? How do you invert the pitch controls? Any help in this matter would be greatly appreciated. I hope I didn't make a mistake in buying this software. Thanks in advance.
geposted Mon 15 Oct 07 @ 5:10 am
Go here and look at the 2nd item - Xponent mappings
http://www.virtualdj.com/addons/view.html?type=tool
geposted Mon 15 Oct 07 @ 5:21 am
Amazing!
I want to try this to see if the Xponent works better with VDJ than it does with Torq but in order to get the mapper I need the pro version! lol! So, the only way I can see if this suits me is to buy the product and hope for the best - typical.
geposted Mon 15 Oct 07 @ 6:34 pm
upgrades and addons are for pro edition owners only.
Them's the Rules.
Them's the Rules.
geposted Mon 15 Oct 07 @ 8:35 pm
mooash wrote :
Amazing!
get the demo and mapp it your self it takes about all of 5 minutes ;)
options > remotes > tick midi and press options
geposted Mon 15 Oct 07 @ 8:43 pm
