how can i remove the background music from a song..and just play the vocals..and add a b.g(instrumental) from another song to it..and with good qualityy..or is there any way i can gte just vocals..?.for example "give it to me" feat timbaland..nelly f..
geposted Wed 06 Jun 07 @ 6:22 am
ello if u look on my last topic i made called cutting music theres some advice on there for ya m8 =0)
geposted Wed 06 Jun 07 @ 3:23 pm
you need the vocal plugin available to pro users
or you need a special program that removes that layer of sound
ie
http://www.softpedia.com/get/Multimedia/Audio/Other-AUDIO-Tools/YoGen-Vocal-Remover.shtml
ie
geposted Wed 06 Jun 07 @ 7:09 pm
I've always wondered, what exactly does the Vocal Remover do? is it 100% accurate?
geposted Thu 07 Jun 07 @ 12:15 am
it targets the frequenies ocupied by voice and removes them
no software solution is perfect
geposted Thu 07 Jun 07 @ 12:56 am
