I've noticed that the samples are now in a .vdj format. What is this, windoze media slayer with play these. I'm just curious why they have a differnt tag.
geposted Wed 29 Sep 04 @ 8:49 am
The .vdj files are mp3 samples (or wav samples if you chose not to encode to mp3) with more information specific to VirtualDJ. This is why the .vdj samples are "beat-aware", ie. they can be synced to the song, etc. :)
macourteau
macourteau
geposted Wed 29 Sep 04 @ 12:41 pm
How do I make my own then?
geposted Wed 29 Sep 04 @ 4:13 pm
When i close and open the program the samples no sincro again ¡¡¡¡ error???
geposted Wed 29 Sep 04 @ 5:41 pm
You must save your samples you create.
geposted Wed 29 Sep 04 @ 5:59 pm
Cyder: you simply record a sample (either set a loop on the song, then press the "RECORD LOOP" button, or press-and-hold the "RECORD JINGLE" button). Once you recorded it, press the small circle at the top-right corner, and choose to save it :)
macourteau
P.S.: you can also load samples the same way
macourteau
geposted Wed 29 Sep 04 @ 8:22 pm
thanks, I just started playing with the sampler for my wedding intros, its quite powerful. I just wish there was another page for 12 more :)
geposted Wed 29 Sep 04 @ 8:31 pm
Hi, is there a time limit as to the length of jingles. as when I try and record a jingle it only records approx 3 seconds. I am holding down the 'jingle' tab. but it does not make any difference if I do or do not hold it down. Am I doing it correctly?. I have Virtual DJ Professional v5.2
geposted Sat 31 Jan 09 @ 2:49 pm
feel the same way, been asking for something like this or similar to a radio cart system for quite a while now, maybe we will get our wish someday...
geposted Sun 01 Feb 09 @ 5:22 pm
