I am using the Boggis DMC2 DLL and 2 nights in a row on opposite decks i had the dmc2 set to scratch mode and the audio started skipping badly. while it was doing so the mode button was constantly blinking and couldn't be changed out of scratch mode until the track was over. It worked fine for a few days and now for the last 2 nights it started this. After the song was over and playing from the other deck i could switch to standard mode and the rest of the night went without a hitch. Anyone else have this problem??
geposted Fri 22 Jun 07 @ 8:39 pm
If the WHEELMODE button was flashing, it means it was in Search mode, which lets you use the jogwheel to rapidly search through the song. Pressing and releeasing the WHEELMODE button toggles through each of the four jogwheel modes, which are as follows:
NOTE: To change jogwheel mode, press and release the WHEELMODE button. Don't hold it down too long or the change will be ignored (This is a safety feature for if you are going to use WHEELMODE in combination with another button and change your mind - Keeping it held down for >1 sec will allow you to release it without causing the jogwheel mode to be changed.)
- LED off = Normal
- LED on = Scratch
- Fast flash = Search
- Slow flash = Param/browse (Different functions depending on which mode the mapper is in (Effects, Video, Samples, etc.)
geposted Mon 25 Jun 07 @ 7:18 pm
