I have Stanton Final Scratch running the older version of Traktor FS.
Both Traktor and Stanton have discontinued support for the software and left their customers high and dry.
So i don't really want to support either of them buy buying any new expensive upgrades.
Is Virtual DJ compatible with the Stanton Scratch amp?
If not - are there any plans to make it compatible?
geposted Wed 27 Jun 07 @ 5:39 pm
currently no for vinyl control , but it may be included in a soon to come update
geposted Wed 27 Jun 07 @ 6:41 pm
but it will work as a soundcard only right? with ASIO drivers?Or am I wrong?
geposted Thu 28 Jun 07 @ 1:59 am
as a normal soundcard
that should be fine yes :)
geposted Thu 28 Jun 07 @ 2:03 am
I tired to use the scratch amp as a sound card on a friends powerbook but it's not that succesfull.
You still have to use the "Mono separated out" option wich is not ideal and you cannot use the scratch amp to record your mix like you can with traktor.
It would be great if the amp was fully supported so that you could get stereo out on both channels and use the amps powerful record feature.
Could a plugin not be written to do this perhaps?
geposted Thu 28 Jun 07 @ 7:32 am
Can you still read the SSL Scratch Amp with the mac Version??
geposted Thu 28 Jun 07 @ 10:00 am
only Support for numark virtual vinyl , was implemented in the first release
others should be added fully later
it should work as a normal sound card the sll box
they are looking into both
geposted Thu 28 Jun 07 @ 10:41 am
