how on earth can you mix w/ a timecode when it jumps back in forth because the pitch changes a hair...
even when i set the pitch sensitivity higher it dosent go away it just takes longer for it to jump..
any help would be greatly appreciated
im running a MAYA 44 USB w a timecode the trial and a stanton str8-80
and im gettin a 100% timecode signal
geposted Thu 28 Jun 07 @ 11:36 pm
what version do you use?
which tcv?
whats your computer spec?
which tcv?
geposted Thu 28 Jun 07 @ 11:45 pm
Set the Pitch Sensitivity to 1000.
It works for me.
It works for me.
geposted Fri 29 Jun 07 @ 1:33 pm
