I have just uploaded a new version:
-> new feature:
* new jog and pitch management (slider removed for a value which is more powerfull and easier to use)
For example: the default value for the jog is 64, if you set a lower value, the scratch will be slower whereas with a higher value, the scratch will be faster.
* selection of the deck
* you can now use effect_slider2() on the second jog, ...
* browser_updown() can now be applied on jogs
* Master tempo buttons are now sync() instead of master tempo
-> bugs fixed:
* loop_length on jogs
* smart_seek() and pitch_bend() corrected
* monitor button inverted
-> new feature:
-> bugs fixed:
geposted Mon 02 Jul 07 @ 12:21 am
Please make update date correct, it still says "Last update: Sat 10 Feb 07"
I somehow managed to use 4.3 version with 4.3 VDJ and Hercules 2006 drivers. Will this new one work also? 2007 are a buggy to me but the Hercules drivers are bad anyways, so...
Thanks for good work!
P.S.
The link is not working, it takes me here:
https://virtualdj.com/download.html#addons
P.S.
geposted Mon 02 Jul 07 @ 9:23 pm
