i can play a 9 hr set (mp3s only) and have no problems and i sit at home with nothing else running and hit anilize my muisc folder and 5 mins in and poff blue screen.
have all the drivers and updates. i do a reboot and defrag befor anilzing and it doesnt do it allways on the same track and some times in differant artist folders but never in the same place twice.
system specs
3.2 ghz pros
1 gig ddr2
gigabyte 8E series (ga-8gpnxp duo)
g-force vid card (dont know what model)
4-160 gig hhd (set up jbod)(music is on 320 gig partion but only 40 gigs of music)
dmc-2
numark cm200usb mixer
when anilizing don have the mixer or dmc on or activated in remote tab
hope this enough info
keep the floor hoppen
system specs
3.2 ghz pros
1 gig ddr2
dmc-2
geposted Mon 02 Jul 07 @ 7:26 pm
Could possibly be a corrupted file.
geposted Mon 02 Jul 07 @ 9:38 pm
Try analizing one folder at a time until you get to the bad one..I found when I analizing mine some samples would cause CUE/VDJ to crash.
geposted Mon 02 Jul 07 @ 9:43 pm
it happen to me i found out every time this was happening
i was scanning DMR file
digital managment rights file which is protected
geposted Sun 08 Jul 07 @ 8:02 pm
Your best way is to do like the above mentioned and do it folder by folder. I have done it like this since I started and it works flawlessly just make sure you make a savedatabase shortcut and use it before closing down VDJ. When I do it folder by folder I actually save after every folder and close and reopen VDJ to make sure I havent lost any info and if all is good I copy that database somewhere safe incase later down the line I get corrupted.
geposted Sun 08 Jul 07 @ 8:24 pm
I have tried even if i scan a file and analyze bpm I get a crash. I am running vista and have the updates running pro the latest (purchased) version, no demo! Why can I not even scan 1 file for BPM?? HELP!
geposted Sun 08 Jul 07 @ 11:45 pm
It might be in your best interest to submit a ticket for service, sorry.
geposted Mon 09 Jul 07 @ 12:33 am
Right click on the VDJ shortcut and select Run As Administrator and try a scan.
geposted Mon 09 Jul 07 @ 7:15 pm
nope still crash...and it is ot a bad file. I hooked up drive to my other pc and dowloaded the trial. It scanned drive with no prob. could it be something in vista ? i ve tried uninstalling and cleaning registry then redownload and STILL SAME PROB!!!
geposted Tue 10 Jul 07 @ 9:15 pm
Then there is a conflict in your PC with VDJ...try turning one program off at a time until you can scan..
geposted Tue 10 Jul 07 @ 11:38 pm
I turned EVERYTHING off, i mean everything and still same result. I need to know how to COMLETELY REMOVE VDJ and try a fresh install. Something is preventing the scan and making it crash. It is not a bad file as I have VDJ installed in nother PC with no prob scanning.....help
geposted Wed 11 Jul 07 @ 12:25 am
Try here........ https://virtualdj.com/addons/download.html?addon_id=2936
hope it helps
hope it helps
geposted Wed 11 Jul 07 @ 12:28 am
nope didnt werk
geposted Wed 11 Jul 07 @ 12:53 am
thank you all for your replys i have found the corupt files that was making it freak out. what gets me thugh is these tracks were ripped from the origanal cd (though the cd was quite old and did have a few slight scatches and i suspect this was the problem). i have since reripped the track and it did anilized just fine. thanks for all the support
geposted Mon 16 Jul 07 @ 5:32 am
Glad you got it sorted and happy mixin!!
geposted Mon 16 Jul 07 @ 6:37 am
well dang it i got rid of it as soon as i found it. but i will rember that for next time. the really odd thing was i tried to play it in wmp and musicmatch and played just fine and it wouldnt play in vdj. came up with a blue sceen wouldnt play at all.
big i tried to rerip it from cd and it wouldnt take cause it had a huge scatch in it. but it was one of the crap song off a 95's greatest hits so its no great loss
geposted Sat 21 Jul 07 @ 5:59 pm
I am having this issue also. Brand new system. Asus i7 with 8MB of mem. Same files I have been using for years. All VOB files. Only trying to do maybe 10 at a time and at least one will freeze up the computer. Never happened before. VirtualDJ had an issue about 1 1/2 years ago after they released an update were VOB files had all kinds of issues. I hope it's not gonna be one of those...
geposted Tue 05 Jul 11 @ 1:43 am
You do realise this topic is 4 years old right, so I doubt it's the same issue I'm afraid.
Please start a new topic with detailed information containing:
* System specifications
* Detailed problem file information
* Crash report if one is generated
* VirtualDJ version
* What changed? Did you change systems and version, just systems or what....
* VirtualDJ version
geposted Tue 05 Jul 11 @ 4:27 am
