Hello my friends..
I want to ask you if there is any way to configure DJM3000 with virtual dj
geposted Sat 07 Jul 07 @ 2:36 pm
The DJM3000 is not a midi (or any other type of) controller, so no there is no way to use the DJM3000 as a controller for VDJ.
All you can do is hook your sound card outs to the line ins on the DJM it to use it as a mixer.
geposted Sat 07 Jul 07 @ 4:22 pm
so i use the djm3000 as a mixer not as a controller can u tell me hoy to connect my djm3000 to my laptop using it as mixer?
geposted Sat 07 Jul 07 @ 5:05 pm
Connect your line out from sound card to the line in on the mixer. You will need a 3,5mm to RCA cable for standard sound card.
geposted Sat 07 Jul 07 @ 5:09 pm
ohh nice i will try it thanks guys
geposted Sat 07 Jul 07 @ 5:16 pm
i cant seem to get this working. o dont see a line in on the mixer. please help!!
geposted Thu 07 Jul 11 @ 1:06 am
wow this post is old... On the djm3000 you will have a total of 8 stereo inputs on the mixer, each channel will have one phono and one line input, you need to use the line as there is a different preamp for phono so it will not sound good when inputting a cd or soundcard signal, if it doesnt say it on the back it should corrospond to the position of the switches at the top of the faceplate.
geposted Thu 07 Jul 11 @ 1:47 am
