Any reggae DJ's here? If so, do you have any "pull-up" samples you use to pull up tunes? Please upload some if you have any, I need some ..thx
geposted Tue 10 Jul 07 @ 5:38 am
or any reggae samples at all? preferrably the "BULLET" sample
geposted Tue 10 Jul 07 @ 5:53 am
i am from Jamaica (home of reggae ) have a couple reggae samples............. you could add me as a contact in MSN and i could send you the samples from here...dont know how to upload samples from here
give me a shout and let me know
geposted Tue 10 Jul 07 @ 6:11 pm
U can use ur virtual dj to create some urselves, all you need is a part of a song that has the required content e.g the bullet one if u r talking about bounty and then under your sampler folder just record the part and make sure you time it well. It might require a few tries but you will have fun doing it and can even make some using a microphone, e.g ur dj name or even some 'fake' dubplates like I did when I first started. Alternatively if you use any file sharing stuff, just type sfx or be specific, like reggae air horn and you'll find all that you need! Bless.
geposted Wed 11 Jul 07 @ 2:01 am
dreadlox, I also would like some samples, if you could send me some it would be appreciated, add me on msn or post your e-mail
thanks :)--Moderated by Lady Cameron<i>Automatic Level 1: MSN or ICQ detected</i>
geposted Mon 16 Jul 07 @ 4:27 am
DJSparkxxx01 for security reasons your message won't appear until a moderator has reviewed it.
if you want to know how to upload samples, just go to www.zshare.net and upload them there and post the link in the thread
geposted Mon 16 Jul 07 @ 4:29 am
lennyndegwa, I know of the bounty bullet sample, and I have many many songs with it, but none of them are acapella so it's hard to record them
geposted Mon 16 Jul 07 @ 4:31 am
O.k Sparkey...u cud use the kill options depending on wat u r using, say if its the mk2, turn the medium knob up and the high and the low down to the desired levels and see if that helps, and also I think the best part to record it is when he's talking before the beat drops.....u know, the famous bounty intro part!
geposted Mon 16 Jul 07 @ 6:38 am
Ok, this is what I did, I used the song Use Bullet (Power Cut Riddim) - Bounty Killer, about halfway into the song there's a bridge where he goes "BOOM BAM BAM CONNECT BULLET BULLET" ..and there's no beat, so I recorded it from the 'bullet' and faded it out using the echo effect it worked pretty good :D but if you have a better sounding version, could you post it?
geposted Mon 16 Jul 07 @ 6:12 pm
i have all those samples not beats at all
geposted Wed 25 Jul 07 @ 5:32 am
could you please send me some of them? I am a reggae DJ and I use samples regularly
geposted Wed 25 Jul 07 @ 7:03 am
could you send me some of those samples please? I am a reggae DJ and use those samples regularly
no contact details are aloud on the forum for non licenced users sorry
geposted Wed 25 Jul 07 @ 12:26 pm
respected skyfxl ..anyways, for the reggae DJ's on here, what do you think the best riddims of 07' are? Personally, the Tremor, Air Waves, After Dark, Power Cut, Timeline/Drumline, Artillery, Bluetooth, Eclipse, and Gully Creature are the craziest ones ..big up reggae everytime !
geposted Wed 25 Jul 07 @ 7:56 pm
HI dreadlox, y dont u upload some of it at here:) n share,, hehe
https://virtualdj.com/addons/samples.html
Thanks mon:)
geposted Wed 25 Jul 07 @ 9:42 pm
dreadlox much respect to all the reggae dj's out here spreading positivity and culture. jah
i have reggae nights every wednesday here at a nearby house and it goes off every week. would love to share ideas and mix with other dj's. dreadlox can i add you to msn? other reggae djs definently post your msn so we can share and discuss ideas about reggae . jah jah love
geposted Wed 25 Jul 07 @ 11:18 pm
anyting by stephen mcgregor is off the meter rite now! He's responsible fi di likes of redbull&guiness , the tremor, and many more that are blazing the charts man! He's only 17 but with a famous name and skillz unmatched, I think he's gon be more big than don corleon and dem! Oh he's the one that did the dav'ille song....on my mind, so if u talking bout riddims then yeah, anything he done is fyah!
geposted Thu 26 Jul 07 @ 4:44 am
I knowwww the McGregor family is doing big tingss, but Don Corleon and Delly Ranx are crazyyy riddim producers too ...also I think beef should be left to hip-hop ..END DI BLOODCLATT BEEF BETWEEN : KARTEL & MOVADO, BEENIE & BOUNTY ...loll they are all crazy deejays and they should do songs together ..everyone in the Alliance mi rate ..dem a badman
geposted Thu 26 Jul 07 @ 5:59 am
