The stutter/play button - how do you change it back to play normal without the stutter effect? The user guide mentions thtat if you double click play it will change into stutter but then how do you get it back to play?
I have been looking inthis forum and see others have this same problem - the suggestions have been to re boot the programme - surely if we are able to put hte stutter effect on we must be able to remove this?
help appreciated thanx!
geposted Sat 21 Jul 07 @ 6:48 pm
What version of VDJ are you using? and please post your system specs..thanks
geposted Sat 21 Jul 07 @ 7:52 pm
go to config > keybooard shortcuts
and look for play_stutter and change it to play
matt
matt
geposted Sat 21 Jul 07 @ 10:33 pm
I'm using Version 4 - will have to come eback to you on system specs.
I have re installed he programme and its seems to be going ok at the mo although it still says stutter instead of play - havent had the chance to have a decent play around yet though.
Thanks for your help - will post again if it re occurs. cheers
geposted Sun 22 Jul 07 @ 5:32 am
