Hello,
Can someone explain how to use the string portion on the DJC Mapper?
Thanks in advance.
FLeX
Thanks in advance.
FLeX
geposted Mon 23 Jul 07 @ 1:48 pm
It's to be used with the following functions:
effect_select()
OR
effect_select_multi()
OR
effect_activate()
effect_select()
OR
OR
effect_activate()
geposted Mon 23 Jul 07 @ 8:56 pm
I apologize for the delay. Thanks DJ Cel
Can you elaborate more?
Can you give me an example. Thanks in advance.
FLeX
FLeX
geposted Sat 28 Jul 07 @ 2:34 pm
For example:
1) Select the function: effect_activate()
2) In the string field, write : flanger
it will make like a keyboard shortcut : effect_activate(flanger)
geposted Sat 28 Jul 07 @ 7:12 pm
Kool !!!
I believe this is what I was looking for...Thanks again.
geposted Sun 29 Jul 07 @ 3:13 am
