Forum: Old versions
Topic: Hercules Mk2 - Page: 2
I have installed the new vdj 6.0.4 pro.My console Mk2 worked fine with the older version.The new software downloaded does not read my console as a mixer and does not show up in my options,also i tried using the ASIO and it keeps on tellin me there is a problem with it. How do i connect my Mk2 up and use it as a mixer again?
I have upgraded my Mk2 drivers and firmware, and instaled the VIrtualDJ 6.0.2. I've set the mk2 to ASIO and tried diferent setting for sond setup in Virtual DJ. The problem is that even thow my speakers work fine, i cannot preview my tracks on the headphones. The headphones only work with the headphones selection knob on Mix or split.
I believe this problem has been fixed since 6.02. You should get the latest update (v6.05).
Please download the latest v6.0.6 trial https://virtualdj.com/download/trial.html
If you have purchased VDJ Pro, then please register the serial number https://virtualdj.com/users/edit.html and download the latest update from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased, then please support the software and its future development by purchasing your own legitimate license: https://virtualdj.com/buy/ - Your Hercules DJ Console Edition entitles you to a discount.
hi, i need support, i buy the hercules dj console MK2 with virtual dj DJC Edition, but 3 days after using it, i have this error message "invalid skin file (error line %i in the xml)" on my screen, when i start the software. i don't find any solution, and i don't know what to do. please help m
Hello dilaw82,
You may have installed VirtualDJ Pro, and changed the skin.
I suppose the best solution now would be to
- uninstall VirtualDJ,
- delete the contents of of the folder 'My Documents\VirtualDJ\Skins'
- and re-install VirtualDJ.
