do this
inputs : none
ouputs : external mixer
card : mk2
channels 1/2 left 3/4 right
on the console software enable external mixer mode :)
for just headphones
inputs : none
outputs : headphones
card : mk2
channels 1/2 main 3/4 headphones
hope to see you as a pro user soon :)
inputs : none
card : mk2
for just headphones
inputs : none
card : mk2
geposted Wed 08 Aug 07 @ 2:10 pm
Thanks once again skyfxl for the quick responce:) but these are the settings im using...i forgot to mention that i already enabled the mixer mode in MK2 control panel..but still the headphones dont work properly, weather its plugged in the MK2 console or in the external mixer (as mentioned above)
Hope to sort this issue out as i cant wait to start mixing properly again...
geposted Wed 08 Aug 07 @ 2:55 pm
Yiddo wrote :
Im using the 4.3 demo version and have set it up with the external mixer.
The latest demo is 4.2?
Please remove that one and use official 4.2 demo ;)
geposted Wed 08 Aug 07 @ 5:01 pm
that would help too unoffical version run havock with ur settings :(
geposted Wed 08 Aug 07 @ 5:36 pm
hi out there ..i am getting static sound out of my mk2 in the headphones and output i downloaded the new drivers 2006 mk2 and updates for vdj my computer is up to specs still get choppy sound,slowed, ect... what do i do?
geposted Tue 02 Oct 07 @ 8:34 pm
Go n download the newer version in ur download area at this site n update ur driver to the latest ones..btw what is ur specs??ram etc?
geposted Tue 02 Oct 07 @ 8:38 pm
my specs are xp..pac2..plll..1133...1ghz..512mb ram..i did update and it helped just a little
geposted Tue 02 Oct 07 @ 8:41 pm
also does mk2 work with traktor 3 or the dj studio version?
geposted Tue 02 Oct 07 @ 8:45 pm
hmm, that i not sure whether it will werk in traktor but i think it can:).. Btw the recomended use with audio, it best to have at least 1 gb ram n since u have only 512 ram try minimized ur background processes running n try not to open a lot of program while opening VDJ as it too take up the ram memory. See if that helps:)
geposted Tue 02 Oct 07 @ 8:50 pm
will do asap..i started things to do to improve my dell latitude..thanks ..i will try to get more memory also..thanks
geposted Tue 02 Oct 07 @ 8:53 pm
:) post here again if the mk2 still have the problem.. All the best.
geposted Tue 02 Oct 07 @ 8:56 pm
My Mk2 Crossfader Is bleeding badly, I took it apart.. and some - how managed to fix it for about a month.. Now its doing it again, and i cant seem to fix it.. Any Ideas?
I also have a rane mixer, Can I hook that up to the console? Would I be able to see the crossfaders move on vdj, as i move them on the mixer its self? I just need to get my crossfader working properly
geposted Sun 07 Jun 09 @ 5:05 pm
