I just bought virtual vinyl a couple of days ago and i need help with it please? I just bought also a new imac intel core duo 2 2ghz cpu 1g of ram and the video card is the standard ati mobility radeon x1600 ,I also installed bootcamp on it. Here are my questions, (1)when i hook up my projector to the computer and play videos with quicktime,vlc it works fine but when i try to mix videos with numark cue there is no sound, what am forgetting to do?(2)it crashes all the time and completely shuts down is this caused by my video card? I installed cue on bootcamped windows xp and to my astonishment it works great but when I hook up to my projector i get distorted bars but this time it is the same for all media players. does anybody have a solution to my problems, thank you. PS. my projector is the benq pb 6110....
geposted Sat 25 Aug 07 @ 2:25 am
which imac do you use?
add your VV serial to your profile so you can get the latest software version :)
geposted Sat 25 Aug 07 @ 3:04 am
i have the Apple iMac Core 2 Duo (17-inch, 2.0GHz) the graphics specs are....Graphics Controller
* Type
* PCI Express x16 - Integrated
* Graphics Processor / Vendor
* ATI Radeon X1600
* Video memory technology
* GDDR3 SDRAM
* Installed Size
* 128 MB
* Digital video standard
* Digital Visual Interface (DVI)
* Max monitors supported
* 2
1 gb of ram ....do you think that i have to install drivers to go with my projector benq pb6110?
* Type
* ATI Radeon X1600
* GDDR3 SDRAM
* Installed Size
* 128 MB
* 2
geposted Sat 25 Aug 07 @ 8:50 pm
ok , please add your serial and download the latest update for vv for mac , that should resolve the crashing
then please tell me what your sound config is
geposted Sat 25 Aug 07 @ 8:56 pm
hi again i don't know if i am on the right forum but lets see . i installed bootcamp on my mac and want to use vv on both systems with a projector but on xp i have a distorted output signal and no sound (see earlier post)when i look in device manager in windows xp there is a yellow question mark under(other devices) when i open it, it says pci device unknown and that the drivers for this device are not installed..this could be my problem
but how do i know wich drivers to install.I also see a yellow exclamation point on usb human interface device and it says this device cannot start...any ideas?
geposted Sat 25 Aug 07 @ 9:44 pm
trying to add serial # but it does not work my vv is store bought is there another site
geposted Sat 25 Aug 07 @ 9:54 pm
please
contactsupport about your serial , as you need that update :)
geposted Sat 25 Aug 07 @ 10:25 pm
thanks, the problem is solved now my cd was corrupt,so i dowloaded directly from the site and everything is okay now
geposted Mon 27 Aug 07 @ 8:30 pm
ok please add your serial to your profile :)
geposted Mon 27 Aug 07 @ 8:34 pm
i cannot add my serial it says add serial for atomixmp3 so my serial is not valid mine is for cue
geposted Wed 29 Aug 07 @ 3:14 am
go to virtualdj.com , login here and
go here to add it ,
https://virtualdj.com/fusers/modifuser.html
go here to add it ,
geposted Wed 29 Aug 07 @ 11:41 am
thank yoy very much for your help..ciao
geposted Thu 30 Aug 07 @ 2:07 am
Hello there i have NUMARK CUE for windows and i do karaoke ad djing how dp i show my website logo on the screen while audio files
are playing and go off when i play a karaoke song or vid,does NUMARK CUE have this feature ?
geposted Fri 25 Mar 11 @ 5:47 pm
hi i need some help please, i have virtual dj 6 pro and i have a new toshiba laptop that works great until i hook up my projector to play videos with my virtual dj its freezes on me all the time and i have to get out of everything and start over...please someone help..
geposted Wed 14 Sep 11 @ 12:41 am
VirtualDJ v6 is an old and out of date version of the software. There have been many changes and improvements to the software since then (See https://virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.5. Most likely the problems that you are experiencing are fixed in the latest version.
Please register your serial number on the page https://virtualdj.com/users/edit.html and then upgrade to the latest version: https://virtualdj.com/download/updates.html
Or purchase the latest version from: https://virtualdj.com/buy/
Please also see https://virtualdj.com/wiki/Performance%20Issues.html
geposted Wed 14 Sep 11 @ 9:17 am
