En cuantos ordenadores puedo instalar una licencia, necesito instalarlo en mi pc de casa para estudiarlo y en el portatil, espero que sea un problema
geposted Mon 27 Aug 07 @ 2:01 am
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
Espero que sepas algo de ingles cualquier duda que alguien que sepa traduzca lo mas importante
Saludos
Saludos
geposted Mon 27 Aug 07 @ 2:23 am
mientras seas tu el que use el programa en cuantas maquinas quieras puedes tenerlo instalado - saludos
geposted Mon 27 Aug 07 @ 3:22 am
