hi matt
any chance you can update your compact 0.99 (1440 x 900) skin version to the latest vdj version (same resolution)? i recently started using comact skin and i found it very suitable for me. i'd appreciate if you decide to updated it.
thanks
thanks
geposted Wed 29 Aug 07 @ 5:32 pm
hi erdi,
i'm still working on a facelift, but it'll take a while
skin function wise, there is almost no change even with the latest version
as i remember one change would be the automix button
beyond that it's pretty much the same
what update do you need ?
let me know the details
and i see what i can do
cheers,
matt
cheers,
matt
geposted Wed 29 Aug 07 @ 11:20 pm
if somehow you can squeeze in "skip" and "cues" without changing the browser size, that would be nice. if not then don't worry about it, cuz i like how the browser size is huge.
thanks for the reply and just wanted to let you know that your skin is appreciated.
geposted Thu 30 Aug 07 @ 4:07 pm
Matt I have a ton of hours spent using your skin, it has been very useful and would like to thank you,I look forward to your updated version.
P@40
P@40
geposted Fri 31 Aug 07 @ 3:40 am
skip ?
like skip beats ?
i use shortcuts
cues ?
like the hot cue and cue buttons from the default skin ?
i use a lot of shortcuts and the way i made this skin is to only display the information i actually need
and to exclude all the functions i usually don't use
i left out the cues on purpose
i have shortcuts for those, too, and wanted to avoid accidents with the mouse
sorry to disappoint you, hope you understand ;-)
geposted Fri 31 Aug 07 @ 5:20 am
P@40
P@40
thanx guys
i'm "happy" that you're "happy" with my skin :-)
hey, btw, i'm working on adding the loop sampler
found a nice spot for it
will get rid of the clone button, too
used to use it once in a while, but not anymore
right now, i'm working on a more "cooler" and "cleaner" look
the buttons and knobs etc...
will take a while, so please be patient
happy vdjing,
matt
geposted Fri 31 Aug 07 @ 5:33 am
like i said earlier matt, don't worry about it. i'm not disappointed, just keep up the good work.
i'm also looking forward to your next "cooler" version.
geposted Fri 31 Aug 07 @ 8:04 pm
Matt0218 wrote :
thanx guys
happy vdjing,
matt
P@40
P@40
thanx guys
happy vdjing,
matt
LOL I can't believe you remembered the loop sampler,your the best Matt,thanks.
P@40 Dan
geposted Fri 31 Aug 07 @ 11:44 pm
I pm'd this bad boy today!
geposted Thu 25 Aug 11 @ 5:51 am
