Turntables are working fine, however when I scratch the TCV VDJ is not picking up the scratch 100%! There seems to be a slight delay,in some cases I loose some of the scratch or movement altogether. What would cause this issue?
I am using VDJ 3.4, as this is the only software that will work with my TCV's. What config's do I need to have everything work 100%?
geposted Tue 11 Sep 07 @ 6:41 am
what soundcard do you use
what spec do you have
have you tried the latest version 5.0 which has a improved sound enginer and tcv engine yet?
geposted Tue 11 Sep 07 @ 5:17 pm
what needles are you using? new or old?
geposted Tue 11 Sep 07 @ 7:37 pm
the needles are brand new. The sound card is the ESI Maya 44 and my specs are 512ram, 80gig HD i forget the processor speed...
Once i upgraded to ver4 of VDj and then got a ASIO sound issue with the TCV's thats why i have stuck with 3.4 cause i know the TCV's work with it.
should i just upgrade to 5 and see what happenes?
geposted Tue 11 Sep 07 @ 10:59 pm
i just upgraded to ver5 and now VDJ isnt picking up a signal from the TCVs... just as i thought!
geposted Wed 12 Sep 07 @ 2:40 am
How do you have it set up, what drivers are you using for the Maya44? Have you tried aisoforall?
geposted Wed 12 Sep 07 @ 3:31 am
I do have the asio4all.
Set up i assume how is everything plugged in?
Turntables go to the Maya44 inputs, and the outputs go to my mixer.
Mixer connects to my computer via USB.
geposted Wed 12 Sep 07 @ 9:07 pm
I'm not sure on the Maya, but on the U46dj there is a switch from phono to line. I assume it's on phono if there is such a switch?
geposted Thu 13 Sep 07 @ 1:58 am
yeah man its on Phono... Its weird though... what else could cause this?
geposted Fri 14 Sep 07 @ 11:49 pm
i have 512 of ram, if I doubled that would that help with the TCV scratch lag?
geposted Fri 14 Sep 07 @ 11:53 pm
Good question bro..I will wait the answer because i'm in the same situation and i can't buy 1 giga of ram for nothing
geposted Tue 18 Sep 07 @ 4:21 pm
I am going to throw a stick of 1 gig ram in my computer so I am running 1512 RAM and see if that works... I have a feelings it will. Everything else works fine, its just seems like its getting bogged down a bit, RAM seems to be the issue here.
This is only what I think though, I'll let you know if this solves the problem when I get my RAM later this week guys :)
geposted Wed 19 Sep 07 @ 4:11 am
Not for nothing, it would help everything in your system run better.
geposted Wed 19 Sep 07 @ 4:17 am
Ram will help, v5.2 will help and then you can start playing with the performance settings to get your best results.
geposted Wed 19 Sep 07 @ 3:26 pm
RAM didn't help me any when I wanted to get better settings, but I think it might be the sucky U46DJ.
geposted Wed 19 Sep 07 @ 6:35 pm
