for couple of weeks Im spending days on bpm matching (the software don't always know the right bpm so I compare with somthing I know it's 100 bpm for sure and than I tell the software the true bpm)
now I want to install the software in my laptop but then I will loose all my bpm work.
I tried in several ways but it seemed to be saved on the computer somewhare not close to the vdj folder.
does anione know where the softare save the data-base????
thanx-a-lot
thanx-a-lot
geposted Tue 11 Sep 07 @ 9:06 pm
sure=shure
what version u using?
geposted Tue 11 Sep 07 @ 9:10 pm
I want to buy the hercules mk2 but for the meanwile Im using the 3.4
and could I transfer all of my manually bpm matching to the new version of vdj?
geposted Mon 17 Sep 07 @ 11:57 pm
The software package that comes with the Herc MK2 uses the 3.4 version of the software. You would need to purchase the Pro Version from this site and yes there are ways to move your information to version 5.
And if you are using a legal copy of VirtualDJ 3.4 then please register it -- https://virtualdj.com/fusers/modifuser.html
If using a crack version then I hope you support VirtualDJ soon by buying the Hercules controller or Pro version soon.
geposted Tue 18 Sep 07 @ 12:40 am
