Somewhere in the downloads section there used to be a plugin available that allowed the user to switch on/off the vocal accompaniment that occurs on some karaoke tracks. They're getting pretty rare nowadays, but I still have a few tracks that are multiplexed, ie the left channel is vocals, and the right channel is music only... The plugin would select either the left or right channel and output it as a mono signal, thus acting as a multiplexing selector switch. Anyone know what happened to this plugin?
geposted Wed 12 Sep 07 @ 1:19 pm
Yes same here, read you could get it in another posting last year but never found it? Any one else help?
geposted Tue 09 Oct 07 @ 11:21 pm
hi lads
you could try these if you have'nt already - downloads > pluggins > sound effects > page 2 Isolator, page 6 vocal remover, and for kjs you might want to try this, page 2 key shifter...hope it helps
Tayla
Tayla
geposted Wed 10 Oct 07 @ 1:22 pm
