I'd like to expand the storage on my computer.
Would it be possible to store everything on a server off another computer or using a network attached storage?
I'm looking to buy a NAS. Would 100mb/s be good enough (performance wise) for mixing in Virtual DJ? what about Itunes(if anyone knows)
Or should I opt for a USB interface instead? 480mb/s
Thanks!
Thanks!
geposted Mon 17 Sep 07 @ 3:25 am
Please register your version of Virtual DJ. Thanks.
geposted Mon 17 Sep 07 @ 3:39 am
Thanks - but its not registered. I am using the Trial to see if it works with Vista/my sound card and an external hard drive before I commit.
geposted Mon 17 Sep 07 @ 4:05 am
OK, well hope to see you soon....
Answer to your question, If you do the networking thing, then it's also going to depend on the quality of your computer/server etc. You create to many "variables." I would just stick to an external drive. That way you can also take it where ever you need it.
geposted Mon 17 Sep 07 @ 5:45 am
I ordered a USB 2.0 drive with raid support. Hopefully it works out
geposted Tue 18 Sep 07 @ 4:36 pm
Hope it works out too. I think you'll be happy with the results.
geposted Wed 19 Sep 07 @ 6:39 am
It does work.
Just takes about 10 seconds to load the "Music: list in Itunes
thanks!
thanks!
geposted Sun 30 Sep 07 @ 4:20 pm
Network storage also works fine, i have 5 different pc's all networked using mapped drives to a vdj machine and it works with no problem at all, it can sometimes take a while to buffer a video file but music files play fine
geposted Tue 02 Oct 07 @ 1:07 pm
