Hi, I recently got a new laptop and i installed everything as needed then when i install the DJ Console Mk2 drivers[got from hercules main website] so when i play a song on deck b and cross fade to deck a, i can still deck b, then when i switch the headphone switch to deck a i can't hear deck b. anybody can help me with this problem?
geposted Mon 17 Sep 07 @ 5:10 am
Hi, Funny I had a similar problem before I purchased the pro version. Make sure you have the latest version Of VDJ (console version) if you have windows vista that is. Also make sure you have the vista drivers and just as importantly make sure the firmwave of the console is up to date (this is included with the latestest drivers and is checked when you connect to the internet)
That should sort it out.
geposted Tue 18 Sep 07 @ 6:40 pm
