how can i use multiple effects using numark total control??
geposted Sat 22 Sep 07 @ 6:14 am
use the sellect knob to choose the effect from the list and the activate button to enable it
you can aso do it on the fx tab
geposted Sat 22 Sep 07 @ 7:08 pm
Is not possible to use multi Fx with default mapping of total control, you can activate only in the FX page of the skin.
geposted Tue 25 Sep 07 @ 3:33 pm
