hey..
i dont know if ne1 among u have experienced this,
i have used virtual dj version 3.xx, 4.03 and 5. In all of them when i increase the tempo to my songs after 2 - 3 seconds there is a missed beat (instead of a thud its a thump!) i tried this over envy24 and creative sb live sound card...same problem..
ne solution to this?
thnx
thnx
geposted Mon 24 Sep 07 @ 11:56 am
Turn off timestretch (master tempo).
geposted Mon 24 Sep 07 @ 4:18 pm
is it the one in performances>master tempo? but i cudnt find an option to turn it off..
thnx alot
thnx alot
geposted Tue 25 Sep 07 @ 6:29 pm
In vdj 3x , under the fame setting.. timestretch enable or disable.. In vdj 4xx or 5 unclick keylock.
Set latency to auto
If u have purchase the software do register it at modify ur profile.. or pls dowload n use the legit demo:)
"Crack" version is bugs prone n may not 100 percent stable.
And if u like the software do support its development by purchasing it.
Set latency to auto
geposted Tue 25 Sep 07 @ 6:46 pm
but unclicking keylock will change the pitch of the track...
ne other methods?
thnx
ne other methods?
thnx
geposted Wed 26 Sep 07 @ 2:54 pm
ne other methods?
thnx
ne other methods?
thnx
Nope.
Simple keylock algorithm --> beat skipping
Advanced algorithm (v4.x and on) --> high latency (slower response time), but better sound quality.
geposted Wed 26 Sep 07 @ 11:01 pm
thnx alot...
geposted Sat 29 Sep 07 @ 12:15 am
