I'm currently running Numark Cue/Virtual DJ off a MacBook Pro and I'm having a bit of trouble with setting up an external soundcard.
I own a Total Control Deck and a M-Audio Audiophile Firewire external card.
The card works absolutely flawlessly when I'm only using one audio output for it, as in if I select to only use one audio driver the card belts out sound perfectly
The problem comes when I try to use a setup like headphones & audio, and split the sound at all, (The entire reason I bought the box for cueing). I'm assuming this must be a software issue because the card works absolutely fine in all other circumstances.
However, when I do this, I get an awful distorted sound that somewhat resembles whats playing but is completely unusable. I was hoping for some assistance. Any help would be greatly appreciated.
If you need any more information about the setup feel free to ask.
geposted Mon 24 Sep 07 @ 6:13 pm
try this
inputs : none
outputs : headphones
card : 4.1
1/2 main 3/4 headphones
performances
fast , and choose autlatency
inputs : none
card : 4.1
performances
geposted Mon 24 Sep 07 @ 6:23 pm
I was praying that would work, but unfortunately no luck.
With that setup I don't get anything playing at all, i tried quitting Cue and restarting it to no avail.
Thanks very much for the help so far though.
geposted Mon 24 Sep 07 @ 6:37 pm
Anyone with other ideas?
Or should I have to hope that its fixed in version 5?
geposted Tue 25 Sep 07 @ 1:57 am
Could it be the card?
If so, does anyone know something that will actually work with VDJ for mac?
geposted Tue 25 Sep 07 @ 7:51 pm
im not sure on this one will try to find out more
a good card to use for this with the mac version is the numark dj/io
geposted Tue 25 Sep 07 @ 8:11 pm
Is it possible to setup with an M-Audio box, speakers and headphones with a Mac-mini? I've been trying to figure it out and had no luck. It seems I'll need to spend $100 on a USB audio drive plug in. But I was hoping I could substitute that with an M-Audio box. What should I do?
geposted Tue 10 Feb 09 @ 9:17 pm
Try this:
Utilities
Audio / Midi Setup
Audio Devices
Configure Speakers
Multichannel
Quadrophonic
Utilities
Audio / Midi Setup
Audio Devices
Configure Speakers
Multichannel
Quadrophonic
geposted Tue 10 Feb 09 @ 9:39 pm
