I have upgraded to v5 and it has been working GREAT for me but I think I may have messed up something in config.. I'm just not sure what.
When I use the automix feature now it only seems to work off ONE player.. whichever one I am playing from when I hit the "automix" button
I am not able to get it to mix using left AND right to save my life now.. can someone help?
thanks
thanks
geposted Thu 27 Sep 07 @ 6:45 pm
It have now been made to werk that way.. so the other deck u could play ard ..:)
U could create macro n have it werk in 2 decks
look here
https://virtualdj.com/forums/75527/General_Discussion/AUTOMIX_SHORTCUT_(For_those_who_miss_the_Automix_button_in_skin___).html?highlight=automix%20shortcut
and the automix in 5 have improved a lot.
look here
geposted Thu 27 Sep 07 @ 7:08 pm
weird.. cuz when i started my gig last nite it was definitely mixing between deck A and B.. then something happened and it started mixing woith only ONE deck. I would not care but for some reason it seems when it does this.. sometimes the next song it loads starts like halfway through the song even if there are NO cues in that song that is being loaded or mixed into...
suggestions?
suggestions?
geposted Thu 27 Sep 07 @ 8:56 pm
Yes in v5 it also werk that way. Even the song is not yet load up, it could still be mix.. U can set the automix to smart, fade in/out or without n also the fade in timing.... and r u sure u use V5 or did u still have the v4xx on ur system too?
U could look in ur v5 pdf manual for more info.. It is located at ur "my documents" in ur system..:)
geposted Thu 27 Sep 07 @ 9:37 pm
