Hi All,
Hope someone can help.
I just put together a brand new system. Here are specs.:
VDJ 5.0 rev 2
XP Pro SP2 32-bit
2GB DDR RAM
320 GB Seagate SATA drive & 500GB WD SATA drive
AMD Athlon 64x2 4200+ CPU
Biostar TF7025 Motherboard
No add-on cards.
Using with Numark DMC-1 (connect via USB-to-serial adapter)
Everything was working fine in previous system. Only item brought over for prior setup was the 320GB drive (which has my working Music collection with VDJ 5.0 database), and DMC-1.
Whenever I try to recurse any folder, VDJ immediately closes down. I see Crash guard flash for a split second. Then I just get my desktop back.
Here's the output from my crash guard log:
Crash ID=000fcab8 (date=709281124, version=5.0 rev.2, build=502, thread=Main, dump=8f05ceca, excode=c0000005 (8,fcab8))
Crash ID=000fcab8 (date=709281125, version=5.0 rev.2, build=502, thread=Main, dump=8f05ceca, excode=c0000005 (8,fcab8))
Crash ID=000fcab8 (date=709281129, version=5.0 rev.2, build=502, thread=Main, dump=8f05ceca, excode=c0000005 (8,fcab8))
Crash ID=000fcab8 (date=709281130, version=5.0 rev.2, build=502, thread=Main, dump=8f05ceca, excode=c0000005 (8,fcab8))
Crash ID=000fcab8 (date=709281209, version=5.0 rev.2, build=502, thread=Main, dump=8f05ceca, excode=c0000005 (8,fcab8))
Crash ID=000fcab8 (date=709281211, version=5.0 rev.2, build=502, thread=Main, dump=8f05ceca, excode=c0000005 (8,fcab8))
Suggestions?
VDJ 5.0 rev 2
XP Pro SP2 32-bit
2GB DDR RAM
No add-on cards.
Suggestions?
geposted Fri 28 Sep 07 @ 6:28 pm
Also just noticed. That attempting to do a search causes same results.
Crash ID=0012f878 (date=709281238, version=5.0 rev.2, build=502, thread=Main, dump=8f058ef8, excode=c0000005 (8,12f878))
geposted Fri 28 Sep 07 @ 6:39 pm
Thanks for the crashguard reports.
We will answer you about these 2 crashes as soon as possible.
geposted Sat 29 Sep 07 @ 6:53 pm
Connected?
Please follow this thread :-
https://virtualdj.com/forums/77074/General_Discussion/A_New_Problem.html?page=1
Note the crashguard codes
geposted Sat 29 Sep 07 @ 8:01 pm
Seem fixed for next release, soon to come
geposted Mon 01 Oct 07 @ 11:29 pm
I tell you what Norway, they should give you a cape with a big S on it and call you SUPERNORWAY.
geposted Mon 01 Oct 07 @ 11:52 pm
