how do i start the recording process? or will it only record if i'm playing a game? I want to record whats on my pc screen. all the settings are set but i can't get it to record.
geposted Fri 28 Sep 07 @ 10:10 pm
use camstudio instead its easier and free :)
http://camstudio.org/
geposted Fri 28 Sep 07 @ 10:15 pm
funkturnal there is a hotkey set for recording, i think its f9 by default. I have used fraps pretty well but it was a huge videi file when i was done.
geposted Fri 28 Sep 07 @ 10:29 pm
I use fraps, works way better than any other capture app.
Sart fraps first.
You need 2nd monitor enabled.
I believe you need video card acceleration enabled
If you see a little yellow numbers in a corner on your second monitor it will work.
F9 to start,
Sart fraps first.
F9 to start,
geposted Fri 05 Oct 07 @ 11:16 am
Sorry for diging out this old post but im kind of stuck on the same issue.
I've been knocking my head like crazy trying to record a video, so i started using default record from VDJ8
i chose webm mode, then MP4, video result is hopeless, the FPS is really bad and the image freezes most of the time.
So i installed back my FRAPS software wich used to work really good with VDJ5.
Now, i cant see the yellow numbers (FPS) there is no sign that the software is recording the VDJ video (i set F9 to activate record)
but when i close the program it prompts me that there is a recording, and ask if im sure to close it.
I also believe that my laptop cant handle video recording, but still wondering why FRAPS does not work with VDJ8
This are my specs.
laptop hp g60 550ca, windows 7 home 64
Thanks !
This are my specs.
Thanks !
geposted Mon 15 Feb 16 @ 8:16 pm
Do me a favor and copy and paste your issue into a new thread. There is no reason to open an old thread like this, because it has no relationship to todays software. Why are you making read a post from 07? Thank you.
LOCKED BY AMAHM
LOCKED BY AMAHM
geposted Tue 16 Feb 16 @ 5:01 am
