I have downloaded two skins but they are in exe format and i need them in zip dose anyone know haw to convert them?
geposted Sat 29 Sep 07 @ 11:23 am
private message me the ones you need + your email and i will try to send them to you later today
geposted Sat 29 Sep 07 @ 2:19 pm
sky can i too PM u the skin i need:)
geposted Sat 29 Sep 07 @ 2:20 pm
sure i will do my best to get them to you today ,
sorry to any one else whos waiting for skins its been a busy week
geposted Sat 29 Sep 07 @ 2:28 pm
thks ..already send u PM.. it only one skin n nevamind u could take ur time")
geposted Sat 29 Sep 07 @ 3:27 pm
Coming soon sky?hee,, if possible can it be b4 27 oct? As i be using my mac for a gig:)
Thanks..:)
Thanks..:)
geposted Fri 05 Oct 07 @ 11:24 pm
If you have a winzip-like program, you should be able to open the .exe as a zip file, then just take the .xml and .bmp from it and put them in the skins directory. I haven't tried it with skin files in particular but have done that with unrelated self-extracting .exe files.
geposted Sun 07 Oct 07 @ 2:09 am
all sent
in this case it wil not be possible to load the exes in this way
geposted Sun 07 Oct 07 @ 2:41 am
