Forum: VirtualDJ Plugins
Topic: Plugin request - video - Page: 1
I'd like to request (for you plugin guys) a plugin
I have no idea how difficult this one would be.....
A bouncing/orbiting JPG
This way we can put our Company Logo and have it orbit the screen; instead of it being static.
Dinner/Cocktail hours - good time for an Orbiting logo, Trade Shows - I could have REALLY used this last week end. and so forth.
Just a suggestion.
geposted Wed 03 Oct 07 @ 9:00 pm
Failing that, I could probably modify ShowLogo to add a "Bounce" button - you resize the image to the size you want using the existing controls, then click bounce to make it move round the screen...?
If you have spare time, it would be great ;-)
I've had video cube and video rotation going at the same time; Looks cool
But I'd really prefer just a 2D bounce.
Like SBDJ said - that would really be cool
I've removed the file - I just realised non-registered users would be able to access it. I'll MSN it across to you Marcel :)
OKay hit me with a pm for msn address
The Internet provider will be at my apartment to install net/cable tv. - I've been deprived for a about 2 weeks.
Only been able to use the net at work.
Thanks, done, link provided above will now work :)
Like I said, it's a quick implementation, I could add a slider to control speed, but I'll probably have to implement the panel as a dialog then (I can't see all the controls provided by that plugin anyway at runtime already anyway - the color mask slider is off the bottom for me) - unless DJ Cel has any input for me on spacing/layout of the VDJ provided parameter controls.
Anyway, I'm rambling, if someone wants to test and see if the logo does indeed move round their screen. Use should be fairly obvious ;)
OKay I downloaded it - Will check back in with you later, after I finish processing videos for play with VDJ.
Thanks for Your work. Much Apreciated.
I get - Can not open file on all common file types -- BMP, GIF, and JPG. Is there something special your plug-in is looking for ?
I get - cannot open this file - d3dx9_35.dll is missing.
I have no idea what that means.
I have it installed in the Video effects folder in Mydocuments VDJ directory.
I'll update when I get home and Check it out then
Thanks
I updated my directX and tryed your plugin modification.
It's Exactly what I had in mind.
Just a slow bounce around the screen with a black background or a video.
I thank you very Much
May you be granted another star!!!!!!!
Now all we need is animated Gif support so you can use an animated logo (like you see on MTV ect).
Then those artistic of us can create a GIF that perhaps morphs between the DJ's name, and the clubs name..
Anyone that wants to tackle that? I'll remember you in my will! =)
I think I noticed this with the original showlogo plugin - IIRC a video window has to be active before you can load the image file.
Glad you approve :) I'll probably make some refinements to the GUI to allow speed control etc....
Hmmmmm... as I've said before, I'm new to this D3D programming malarkly, although I guess that might be a good time to start learning to use the DirectShow API. Certainly worth investigating :)
Hey SBDJ You should upload the new version of this plugin to the plugin board so that everyone can share in your creation.
It really did make me happy.
Good work again!!!
Well it's all DJ Cels work, I just made a few tweaks, I won't do anything without his approval :)
Would be nice if we can have an option to load automatically the album cover as logo
Thats a pretty cool idea, I am sure it would be low on the cpu usage (lower than sonique) may be somethin to add a little spark to the show:)
87%
