the title sums it all
my vdj works fine as long as i dont plug in my total control.....and if it doesnt freeze...when i click and activate total control..the light is red and it wont work until i unplug the total control..i dont know if its my soundcard that is doing that.
i have an ESI u46dj
2 gig ram
dual core processor and x2 4600+
i checked sky's irq blog....still trying plz..i need help
i have an ESI u46dj
2 gig ram
geposted Sat 06 Oct 07 @ 8:29 pm
what version are you using v5?
does the total control show up in windows ?
right click my computer press properties , then look for hardware and then hardware manager
check if the TC shows up
check the cables and try a different usb port
it is aslo possible you have run out of power on your usb bus
or are out of bandwith
try a usb hub or installing another usb card,
geposted Sun 07 Oct 07 @ 1:15 am
problem fixed..IT WAS AN IRQ CONFLICT!!!
geposted Sun 07 Oct 07 @ 2:53 am
those rascaly irqs !
good to here your sorted
geposted Sun 07 Oct 07 @ 1:49 pm
well said sky.....thnx for all the help.....neeeded all of yo grandmaster experience.......whats next for u sky..world domination..ahahahhaha..jking of course....cheers to sky....
dj reaper
geposted Mon 08 Oct 07 @ 5:58 am
