Hi, could someone please let me know if there is any hardware out there that works with Windows 2000?
Please help
Please help
geposted Sat 06 Oct 07 @ 10:14 pm
2000 is now a legacy product hardly any new music hardware works with it
and it is likely any hardware which can only run 2000 is not good enough for live performance
what is your spec?
what is your spec?
geposted Sun 07 Oct 07 @ 12:56 am
Hi, thanks for getting back to me, what info do you need to know?
geposted Sun 07 Oct 07 @ 10:07 am
processor , ram , video card
ect
ect
geposted Sun 07 Oct 07 @ 12:25 pm
Processor is Intel Inside Celeron, ram is only 392kb & only 5GB of space. I'm a bedroom DJ, who like's to do CD's & the occassional house party who want's to be able to monitor the track I'm mixing in, unfortunately I cannot afford a new lap top at present so it doesn't look like a get find a DJ Console/audio interface thats suitable, unless you can help? The main thing I want to do is monitor the track I'm mixing in, if there's any products out there that you are aware of, I would love to hear from you.
P.S Device, must work through a USB Hub.
geposted Sun 07 Oct 07 @ 10:38 pm
there is no controler which can support this unfortunately
vdj wont run on that either
you may be able to run a older 4.1 soundcard on 2000
and prelisten with atomix mp3
www.atomixmp3.com
ultimately a better solution would be to get a refubished newer pc
www.atomixmp3.com
geposted Sun 07 Oct 07 @ 10:49 pm
Thanks for your advice, appreciate it
geposted Sun 07 Oct 07 @ 11:09 pm
Only DJ Software and Controllers that were avail during that era will work.
Try Searching For DJ App reveiws from 2000/2002
geposted Mon 08 Oct 07 @ 4:50 pm
