A friend of mine loaded the latest version of VDJ and while it was running it cut out etc the CPU meter was full, dose this mean his processor is not powerful enough?
geposted Mon 08 Oct 07 @ 7:15 pm
What are the specs of the system he is using?
By default, I would answer NO, because you will see spikes to 99% on single core machines when a track is loaded; 50%+ on dual core machines are 100% 1 CPU/ Low load on 2nd CPU = 50%+ overall.
So it's easier to answer that question with some specs about the machine (CPU, Memory, etc )
geposted Mon 08 Oct 07 @ 7:19 pm
just emailed him n got the spec of the laptop he was using.
768 ram 1.5 pentium m centrino processor 40 gb hard drive
geposted Mon 08 Oct 07 @ 11:14 pm
Well that explains his performance issues --
* PIV 3 GhZ computer
* 1024x768 SVGA video
* 4.1 DirectX compatible soundcard (with front and rear separate outputs)
* 1024 MB RAM
* 200 MB free on the hard-drive
* 1024 MB RAM
geposted Tue 09 Oct 07 @ 2:23 am
