OK.. Using the Maya44usb and I want to use the built in mini plug for headphones. How can I set this up in the software?
geposted Tue 09 Oct 07 @ 4:13 am
I'm not sure if I'm understanding the question, are you referring to the mini plug on your comp?
geposted Tue 16 Oct 07 @ 7:27 am
Hiya, I\'ve got the maya 44 usb as well.
Unfortunately, as far as I know, the headphone socket will only output the total from all channels of the card, so it can\'t easily be used for cueing.
What I\'ve done in the past though is to use a short adaptor cable with 2 phono plugs on one end and an inline stereo mini jack socket on the other. PLug that into outputs 3 & 4 of the maya card and then you can use it for headphone cueing!
Then in VDJ you can set it up for headphones on 3&4 and main output on 1&2.
Personally though, I use a DJ mixer with the card, so I simply plug into two channels of mixer and use the inbuilt heaphone socket on the mixer.
geposted Wed 17 Oct 07 @ 5:09 pm
