i just installed in my pc the ESI MAYA 44 PCI ,and first it doesn't let me configure the ASIO 2.0 FROM virtual dj,I click it and nothing happened,i also sounds so bad,like frying noise.It is not a speed problem,since it is running a 6000+ in 4 gb of memory,it only runs higher latency,when i do have the maya 44 usb and i can run it at 1ms,why doesn't the PCI run better?
I suppose to be better than the USB.The only way i can make it work is by installing AISO4ALL,then it seems to work fine at 1ms and now i can configure from VIRTUAL DJ.But it seems not to like the original ISO2.0.
My question is:any idea of what causes this problem?
P.S:one thing i notice better on the PCI version over the USB,it has higher volume.
geposted Thu 11 Oct 07 @ 3:14 am
