Hi.
When i play a movie its fine but as soon as the file ends i hear a horrible digital noise, almost like a synth, saw wave or something. It doesnt happen when music ends, only movies. My vinyl is in absolute mode. Any idea on what it could be?
Thanks, Ben
Thanks, Ben
geposted Thu 11 Oct 07 @ 1:50 pm
Windows or mac?
what format?
what format?
geposted Thu 11 Oct 07 @ 1:56 pm
mac. Its the free sample movies that you get when you install. Any ideas? Thanks, Ben
geposted Thu 11 Oct 07 @ 2:43 pm
does it do it on all videos or just the sample ones , where do you have your performance slider set at the moment
which mac do you own , does it have shared or dedicated graphics memory and how large is the memory?
what file extension are they .avi . mpg?
just a lil tip for the future please post in the mac forum or mention at the start your using a mac because people will assume you are using windows and give you the wrong info for windows
mod : moved to mac forum
geposted Thu 11 Oct 07 @ 4:32 pm
I only have samples in my computer at the moment, i havent put any others on there as they are ripping to an external harddrive in the other room. They are mpg's. Its a MacBook Pro 2.4GHz Core Duo, 4 Gig Ram, 160GB Hard Drive. Shared or dedicated graphics???
Thanks, Ben
Thanks, Ben
geposted Thu 11 Oct 07 @ 5:37 pm
We are in the mac forum. . .
geposted Thu 11 Oct 07 @ 5:38 pm
ok i will investigate this one for you
i moved your topic here from the hardware forum
geposted Thu 11 Oct 07 @ 6:32 pm
Any luck yet? Thanks, Ben
geposted Tue 16 Oct 07 @ 12:28 pm
geposted Wed 17 Oct 07 @ 4:46 pm
i have flaged it for the attention of the developers
so it should be sorted in the very soon to come update :)
geposted Wed 17 Oct 07 @ 8:54 pm
Thanks, Ben :)
geposted Thu 18 Oct 07 @ 11:28 am
