i found where is my problem but i can't resolve it alone :
my dj console is recognise by vdj in the remote/midi place but i can't use the mapper available to download because it is a .exe and i'm on a mac
is there a way to extract the config from a pc to a mac ???
geposted Thu 11 Oct 07 @ 10:56 pm
unfortunately no this plugin would need to be re coded to mac format by its author
you can adjust the behabiours manualy by mapping the console to your wishes
tick the midi option and press options and map your desired actions
geposted Thu 11 Oct 07 @ 11:01 pm
