Alright, I am back from my little event I had yesterday with v5.0.4 of VirtualDJ. I ran for about 5 hours with a few issues.
I had two crashes while playing video and searching through the database. I clicked on the "Side List" and I got the famous Crash Gaurd screen. My second one came after trying to load a video into the ClipBank. The most frequent issue I was having was that the tracks I was playing skipped (like a scratched CD) about every 2 minutes. It was annoying, I checked my CPU history to find the culprit and VirtualDJ seemed to spike up while just playing music. At the time I was not at my computer, so I was not doing anything to cause it, but I was near enough to hear the music.
AutoMix while I was eating, worked fine with the Fade 16s option, but I did not like that every time I went to turn it on it was set to "Smart" be default so I always had to set up the "Fade (remove nothing)" options.
I clicked on the check box to "Send Report" on both crashes, but I did not have an Internet connection. Anyway that is is saved on my computer so that I can send it? I just got it crash again while loading the same video and sent the report right now. Does VirtualDJ send it immediately?
geposted Sun 14 Oct 07 @ 8:37 pm
C:/programfiles/virtualdj
or
my documents / virtualdj
crashgaurd.txt
or
crashgaurd.txt
geposted Sun 14 Oct 07 @ 10:11 pm
Found it, thanks! Does the report overwrite the previous one I had when only searching for videos? That would be nice to not have a simple search in VirtualDJ crash it or while expanding the "Side List".
Crash ID=004a6fc8 (date=710131749, version=5.0 rev.4, build=504, thread=Main, dump=80387c74, excode=c0000005 (0,560022ec))
Crash ID=0a9a2edf (date=710131912, version=5.0 rev.4, build=504, thread=Main, dump=8b45008b, excode=c0000005 (0,0))
Crash ID=04a92edf (date=710141432, version=5.0 rev.4, build=504, thread=Main, dump=8b45008b, excode=c0000005 (0,0))
geposted Sun 14 Oct 07 @ 10:23 pm
I have some problen when i upgade to version 5 rev4. Please help?
/karrobarro
CRASHGUARD
date=708200000
version=5.0
build=500
thread=Main
address=00450942
ins=890683c6
excode=c0000005 (1,9728f324)
Crash ID=00438fdd (date=709192110, version=5.0 rev.2, build=502, thread=Main, dump=8b481089, excode=c0000005 (0,10))
Crash ID=0040b940 (date=709252228, version=5.0 rev.2, build=502, thread=DSOutputSafeBasic, dump=0fbf2a0f, excode=c0000005 (0,45b1a000))
Crash ID=0040c4e5 (date=709281903, version=5.0 rev.2, build=502, thread=DSOutputSafeBasic, dump=8b048a89, excode=c0000005 (0,19907000))
Crash ID=0040b8c0 (date=709282007, version=5.0 rev.2, build=502, thread=DSOutputSafeBasic, dump=0fbf1a8b, excode=c0000005 (0,ae19d04))
Crash ID=0040b8c0 (date=709282008, version=5.0 rev.2, build=502, thread=DSOutputSafeBasic, dump=0fbf1a8b, excode=c0000005 (0,ae19d04))
Crash ID=0040b8c0 (date=709282010, version=5.0 rev.2, build=502, thread=DSOutputSafeBasic, dump=0fbf1a8b, excode=c0000005 (0,b1fa21c))
Crash ID=00438fdd (date=709282027, version=5.0 rev.2, build=502, thread=Main, dump=8b481089, excode=c0000005 (0,10))
Crash ID=0044edb0 (date=709291348, version=5.0 rev.2, build=502, thread=Main, dump=f70408ff, excode=c0000005 (0,8061c78))
Crash ID=0044edbf (date=710022204, version=5.0 rev.2, build=502, thread=Main, dump=8b078bd8, excode=c0000005 (0,825d384))
Crash ID=0044edb0 (date=710022353, version=5.0 rev.2, build=502, thread=Main, dump=f70408ff, excode=c0000005 (0,8061c78))
Crash ID=09b9152c (date=710031742, version=5.0 rev.2, build=502, thread=Main, dump=c74024ff, excode=c0000005 (1,26))
Crash ID=09b9152c (date=710031748, version=5.0 rev.2, build=502, thread=Main, dump=c74024ff, excode=c0000005 (1,7c9165a2))
Crash ID=0395152c (date=710122011, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,3966336))
Crash ID=03f0152c (date=710131822, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,3f261e4))
Crash ID=09be152c (date=710131939, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,690098))
Crash ID=09b6152c (date=710141708, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,64))
Crash ID=09b5152c (date=710141711, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,b2d8))
Crash ID=09b5152c (date=710141712, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,16d9))
Crash ID=09b6152c (date=710141716, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,70a9))
Crash ID=09b5152c (date=710141719, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,e89b))
Crash ID=09b5152c (date=710141734, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,69))
Crash ID=09b5152c (date=710141736, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,7c910756))
Crash ID=03e7152c (date=710141746, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,69))
Crash ID=09b7152c (date=710141748, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,22))
Crash ID=09b6152c (date=710141750, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,9fac))
Crash ID=09b7152c (date=710141826, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,69))
Crash ID=09b6152c (date=710141832, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,9b8a810))
Crash ID=03e8152c (date=710141846, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,69))
Crash ID=09b7152c (date=710141848, version=5.0 rev.4, build=504, thread=Main, dump=c74024ff, excode=c0000005 (1,22))
/karrobarro
CRASHGUARD
date=708200000
version=5.0
build=500
thread=Main
address=00450942
ins=890683c6
geposted Mon 15 Oct 07 @ 7:18 pm
@karrobarro
Thank you for the reports. You can now delete the "crashguard report.txt" file.
Could you describe how you can reproduce this crash in v5.0 rev4 (it's always the same) ? A plugin ?
geposted Mon 15 Oct 07 @ 10:50 pm
No, it adds data at this end of the file. That's why it's very important to delete the file as soon as it's reported on the forum.
geposted Mon 15 Oct 07 @ 10:55 pm
Oh, OK, so this is the error I first got then. Thanks. Deleted now. It opens better in WordPad I noticed too even though it is a TXT file.
geposted Tue 16 Oct 07 @ 12:08 am
