Hello All,
1. I just Dee Jayed a party, and I had skipping issues with DJ Cue. Everytime I loaded the next song in the desk the sound would skip on the oppisite deck. I think I figured out the issue , for some reason I had the Config>Performace Setting set to high.
But What made this change? I was really upset when the whole crowd kept looking at me when the songs skipped.
Before I get into bed with DJ Cue , I want to make sure it's stable.
I had some other issues:
2. When I tryed to play an international song, which when I ripped the CD the languange of the tracks titles are not engilish. DJ Cue crashed when i tried to load the this song.
3. Also, If i do purchase this, is there a diffrence between DJ Cue and Vitual CD ?
Thanks All.
I would really appreciare some input here, I have a party in 10 days and I dont know what to do!
Thanks All.
geposted Mon 15 Oct 07 @ 4:19 am
Well I think you have actually identified the things you need to do...
1. Make sure the performance settings are correct for the ability of your computer before you go to a gig
2. When ripping songs that contain international characters I would modify the files before using them in VDJ
3. Numark CUE and VirtualDJ are the same, they are just branding difference.
geposted Mon 15 Oct 07 @ 4:42 am
