Hi,
how do i get virtualdj to find my usb microphone?
geposted Tue 16 Oct 07 @ 6:41 pm
there is a mic plugin for pro users
, but usualy if you have it set in windows control pannel it should work
what vdj do you use?
geposted Tue 16 Oct 07 @ 9:02 pm
im using virtualdj 5.0 professional, how do i set this up? because im starting a radio show soon and i need it to work
geposted Wed 17 Oct 07 @ 8:30 am
djsaders
if you've recently bought the software its best to register it, then you will get full benefit of vdj pluggins etc. if you have'nt and are using a illegal copy i would not go anywhere near to broadcasting with a dodgy copy because it will definately screw up at the worst possible point, either way hope either suggestion helps...
Tayla
Tayla
geposted Wed 17 Oct 07 @ 1:29 pm
Stop using a cracked version
geposted Thu 18 Oct 07 @ 8:34 pm
Besides of what vdj version you use, will you "star a radio show" and use a software plugin and a usb mic, instead of a professional broadcast mixer/console, (or even any cheap mixer)
I think this is the END of the radio as we know it...
geposted Sat 20 Oct 07 @ 2:47 am
