so I'm still using 4.3r12 after installing 5.0 mainly because of the looping issue I'm having using tccd.
I add files/analyze new files to 4.3r12 and also to 5.0 but when I want to backup the database of 4.3 the last modified date says Sept 5! is it adding these files to that databse or not? how can I save that database so I can back it up?
I'm still hesitant to using the latest version but will probably give it a try after I redo the laptop first of november.
Not sure if this was fixed with the latest version but what stopped me from also using 5.0 at one place where I could use clipbank is I went from the clipbank to type in a song search and the infamous crashguard screen came up. I had been letting the same clipbank file loop for a long time...say 10 mins. I was thinking maybe vdj just got tired of looping it. lol
Thanks for some answers on this. :)
geposted Fri 19 Oct 07 @ 7:10 pm
When you installed 5 the home folder for the database changed to the My Document -> VirtualDJ folder. So check that location for your latest 4.3 database.
(This was a registry entry change)
geposted Fri 19 Oct 07 @ 7:40 pm
Ahhh Bingo! Thanks Chris.
geposted Fri 19 Oct 07 @ 7:43 pm
