Hi,
i want to ask if it's possible to copy the information (bpm, cue) and so on from my desktop pc to my laptop.
I use a external USB-HDD and I put all files onto it - drive P:
when i setup the external hdd on my laptop as P: too can i use the bpm information?
where is the bpm information saved? in the mp3databse.txt or in the xml file?
I just found VirtualDJ Database.xml in the VDj directory. Oh - and i got Version 3.4 for console - but won't make any difference in that issue?
Thank you :)
Thank you :)
geposted Wed 24 Oct 07 @ 7:57 pm
copy virtualdjdatabase.xml
virtualdjdatabase(yourname).xml
and mp3database.txt
from the program directory to the other computer
and mp3database.txt
geposted Wed 24 Oct 07 @ 8:30 pm
thx man :)
where do i find the xml - is it the one in documents & settings?
in my virtualdj 3.4 fodler thereis only virtualdjdatabase.xml and mp3database.txt -.-
geposted Wed 24 Oct 07 @ 8:40 pm
copy those two there should be another xml in program files
c:/programfiles/virtualdj
called virtualdjdatbase(yourusername).xml aslo
geposted Wed 24 Oct 07 @ 8:44 pm
it'S not there. i installed demo's of v4 and v5 too - does that have an influence on those xml'S? :(
geposted Wed 24 Oct 07 @ 8:50 pm
if you installed 5 over the 3.4 and have been adding things to 5 , they wont be saved in your old 3.4 database
try copying just the two files and seing if it loads ok
geposted Wed 24 Oct 07 @ 9:58 pm
