Hello I Recently Bought The MK2 And Its Helpful For Me Making My Mixes, But I Started Having Trouble With Virtual DJ When I Scratch The Program Freezes, Is It A Problem With Virtual DJ Or My Computer Is Too Old Already? I Have a Desktop Hp Pavilion Celeron 1.7Ghz And 750 Mb Of Ram, Please Help
geposted Fri 26 Oct 07 @ 11:54 pm
are you using timecodes or do you mean the jogs ?
i would get more ram
are you using the 3.4 version?
geposted Sat 27 Oct 07 @ 12:38 am
I Have The Hercules MK2 Console and I Use The Jogs To Scratch, But I Think There Was Some Wrong With The Program i Reinstalled It N Seems To Be Finne For The Moment, Thankz For The Help
geposted Mon 29 Oct 07 @ 6:00 am
Well, though mk2 works perfectly well, it does backfire at times. I had a similar problem( posted in the forums earlier) and even re installing didnt help , i then updated the s/w and then all works fine, though still now when i play for 7 - 10 hrs at a stretch i suddenly get a horrible frequency just deafening all in the floor!! Restarting the SOFTWARE alone helps!! Anyway try this out if you have a problem again
geposted Wed 31 Oct 07 @ 8:42 am
