Forum: Old versions
Topic: how to rip vinyl - Page: 1
please can someone tell me how to use the rip vinyl part of vdj. i get sound but i get an error message that says impossable to save, what am i doing wrong?
geposted Sat 27 Oct 07 @ 4:26 am
sbangsPRO InfinityMember since 2004
what version do you use
which soundcard?
geposted Sat 27 Oct 07 @ 1:59 pm
i use vdj 5 and i use a maya44 (usb). i run the program on a sony vaio, 3ghz, 1g ram, 80g harddrive. the intergrated soundcard is a realtek (just a line out,mic in, and a headphone jack). i use a berringer vmx1000, 5 channel plus to mics. any help is greatly acepted. thank u
geposted Sat 27 Oct 07 @ 2:15 pm
geposted Sat 27 Oct 07 @ 2:30 pm
ok i downloaded it and installed it(i think), what do i do now? thanks for any help
geposted Sun 28 Oct 07 @ 5:29 am
try to record , see what happens
geposted Sun 28 Oct 07 @ 11:31 am
still says impossiable to save. also where do i put that lame plugin at.
geposted Wed 07 Nov 07 @ 11:15 pm
skyfxl wrote :
http://www.free-codecs.com/Lame_Encoder_download.htm
download and extract this to the virtual dj program folder
C:/programfiles/virtualdj
and aslo to the virtual dj folder in my documents
geposted Wed 07 Nov 07 @ 11:16 pm
ok i did that and i started to record, when i go to save it i get an error message "impossible to save". what am i doing wrong? thanks for ur help
geposted Thu 08 Nov 07 @ 3:12 am
now it should be fine :)
geposted Thu 08 Nov 07 @ 2:11 pm
thanks alot for ur help, vdj is the best program out i love this s@#t. works like a charm!!
Moderated by Lady Cameron
Sorry beatbreaker1 no email address is allowed from a demo user
geposted Fri 09 Nov 07 @ 5:40 am
hope to see you with us soon as a pro user :)
geposted Fri 09 Nov 07 @ 2:34 pm
to become a PRO USER what do i have to do? thanks for your time.
geposted Tue 13 Nov 07 @ 2:32 am
geposted Tue 13 Nov 07 @ 7:01 pm
I am having issues as well.... I can rip the vynl to pc and save it with no issues. My problem is the quality.... Either it is too low or too loud. Too much bass or too much treb.... Cant seem to find a happy medium...
Any suggested settings????
TIA
DJKenzoNYC
geposted Mon 19 Nov 07 @ 8:24 pm
adjust the gain and volume sliders acordingly until it sounds correct for your record
geposted Mon 19 Nov 07 @ 9:38 pm
yes i to had this problem, just do what skyfx said and it will be just fine. it may take a couple of trys but it will sound good.
geposted Tue 20 Nov 07 @ 5:00 am
Ok i have it configured like SKYfx said, but when the program starts i get "Impossible to find LAME encoder DLL" I am using the 20 day trial, waiting for my real version to arrive. I have copied the LAME encoder dll to the same directory as the exe and that doesn't help either. What is it looking for? Do i need to down load a diffrent version of the LAME as mentioned further up in this thread?
geposted Wed 09 Jan 08 @ 1:42 pm
vdasssHome userMember since 2008
hi all , thanks for all the info in this post , i followed all instructions but programe still tell me impossible to save. ? using 4,0
geposted Wed 09 Jan 08 @ 6:49 pm
please try the latest official demo you will find it has better results.
geposted Thu 10 Jan 08 @ 12:33 pm
54%
