Guys,
In the VDJ 5 v5 userguide you see under new options:
Retrieving ID3Tag Data
There is a tab for : Browser ->infos gathering ->Title/Artist
Then there is a button to select: Smart, Only from Filename, or Only from Tag.
However, I do not see those options or even that button on my vdj5 v5 install. Did the userguide not get updated properly? Or is something wrong with my install? The only button I see in place of the smart button is: id3tag: Enable/disable.
Can someone please confirm this? Thanks.
geposted Sun 28 Oct 07 @ 6:03 pm
Well, I just checked under my documents and saw that the VDJ userguide that came with v5 is updated. I guess the online version did not get updated yet.
So, they did away with the Smart button?
geposted Sun 28 Oct 07 @ 6:08 pm
That's the way it is in my v5 install as well. Guess that's one of the stability improvements, maybe ;)
geposted Sun 28 Oct 07 @ 6:27 pm
The User Guide was updated with Revision 4. The revision 4 guide is the one posted on the website in the guides. No significant changes were made in revision 5 to make changes to the user guide.
Also, if you look at the top-right corner of the guide's cover graphic it will state - Revision 4 - that is the latest guide version.
geposted Mon 29 Oct 07 @ 7:49 pm
