just want to say to dams : i bought some more ram to upgrade to 512mb and now it runs pretty well. definately usable.
anyways - my question is.
i need some advice for recomended keyboard shortcuts.
what ones do u guys have set which make life really easy.
can you please tell me what u have, or how you setup your keyboard.
thanks
thanks
geposted Sat 12 Jul 03 @ 7:20 am
It all depends really what features you use really
geposted Sat 12 Jul 03 @ 11:41 am
im just asking for some reccomended.
like what are you using etc?
i will make my own shortcuts according
to what seems helpful
geposted Sat 12 Jul 03 @ 6:48 pm
I hate having to switch desk to be able to use loops, effects, pitch, nudging, or anything else.... so I select the shortcuts i need or use the most and define keys to those shortcuts to both desk.
For Example... Q W E A S D are the loop-buttons for left desk... R T Y F G H for the right....
Z X C are effect-buttons for left desk and so on...
I use the arrow keys to nudge active and playing desk...
I Use an external mixer so lots of keyboard keys don't have to be used on EQ-, crossfader-, volume- shortcuts.
geposted Sun 13 Jul 03 @ 12:58 pm
