Hi
I'm using Virutal DJ 5 and I hear a little bit of pop when using equalizer on Hercules MK2. (especially when using it fast)
Has anyone had this problem also? If you know a solution to this please let help.
Thank you very much.
geposted Mon 29 Oct 07 @ 10:54 pm
what is your system spec?
are you using the demo or pro?
geposted Mon 29 Oct 07 @ 11:24 pm
I have both Virutal Dj 3 and 5.
It doens't have that annoying problem in 3 but in 5 it happens.
But I remember hearing nothing like that before today.
thanks.
thanks.
geposted Mon 29 Oct 07 @ 11:28 pm
please add your pro serial to get the latest patches
https://virtualdj.com/fusers/modifuser.html
geposted Mon 29 Oct 07 @ 11:34 pm
Hello,
I have the same problem, but not any time :(
VDJ Nicco
VDJ Nicco
geposted Thu 01 Nov 07 @ 2:09 am
I used to have this trouble, but not since I changed my setup. Check my blog for details.
geposted Sat 03 Nov 07 @ 8:01 am
diskjockydoc, i can;t find your blog with this info, can you help me out?
geposted Sat 03 Nov 07 @ 7:45 pm
I'm having the same problem, i have the latest updates from Hercules.
Cant find your blog either.
geposted Sat 03 Nov 07 @ 9:53 pm
it is set to pro user level
geposted Sun 04 Nov 07 @ 1:52 am
:( Unset it to Home user please.
geposted Sun 04 Nov 07 @ 1:03 pm
