Everytime I try to close VDJ 5.0 REV 5 This is what it tells me.
Warning!
The system was unresponsive. Virtual DJ has performed a recovery, and should now work ok again. Still, you might want to restart the software next time it's convenient enough for you to do so.
I have restarted my computer and program multiple times, re-downloaded the full-intstall with no success in fixing this issue.
Warning!
geposted Mon 05 Nov 07 @ 9:58 am
If you are using a DAC-3 controller, this is because the DAC-3 is not releasing properly when VirtualDJ shuts down. Please see the General Forum for several threads on this matter.
geposted Mon 05 Nov 07 @ 4:10 pm
I am using a Dac 3... I will check into that when I get home, thank you for the quick response!
geposted Mon 05 Nov 07 @ 11:17 pm
I went onto the forums and looked up the threads about this matter... What I found out was that nobody really knows how this problem starts, but bottom line it seems to be more of the Dac 3's fault and WAY to confusing to fix once it starts happening.... Another controller in the garbage =)
geposted Wed 07 Nov 07 @ 7:27 pm
As much as I know the problem is with the newest update (5rev5) and has to do with the software not disconnecting the mapper for the controller correctly. This issue get's worse ... after 3 successfuls shows I now have been experiencing the loss of my entire codec regestry. There are only a few discusions on these matters and most focussing on the DAC 3 cause and some now mentioning the codec registry issue.
I know for a fact that it has been addressed and there is a cure on the way.
This all has more to do with the updates (new) recovery system in this version having a bug, than anything else!
NOW .... who can tell me that the fix is coming out today??????
geposted Wed 07 Nov 07 @ 7:50 pm
Dev staff is currently trying to fix this problem.
geposted Wed 07 Nov 07 @ 10:08 pm
Thanks for the update DJCel... I'll wait it out then.
geposted Wed 07 Nov 07 @ 11:24 pm
People are correct when they say this problem only gets worse... My program started crashing last night at my show uncontrollably and refused to load any music until I completely disconnected the Dac 3 and restarted my computer... wow.
geposted Fri 09 Nov 07 @ 8:25 pm
It was solved in v5.0 rev.6
geposted Mon 03 Dec 07 @ 2:12 am
